bag question
kyllokustoms@yahoo.com's avatar
bag question
jealousonezenvy's avatar
jealousonezenvy
i got my bags all set up lines wires and everything my question is this i have one compressor that fills my 6 gallon tank but it takes forever. I have digital gauges also. whats the amount of air they are suppose to have? my truck gets aired up then minutes later its empty in the bags ive looked for leaks but nothing there were a few little ones but it takes forever to get air to my front. all te valves and tank are in the bed by my back of the cab. any suggestions?
SIKaltima's avatar
SIKaltima
i think thats the main thing is that the valves are in the bed, i have always found having your valves mounted closest to your bags as possible is definitly going to be a lot quicker
jealousonezenvy
i will move the front valves near each wheel but away from debris.
impulse's avatar
impulse
bad check valve? does that make sense?
bagdb2200
Edited: 5/14/2008 10:24:59 PM by DroptSdime
Word. I think it may be the check valve on your compressor leader hose or something similar. I don't think it's the location of the valves because my Mazda has 6 gallons of air(2 3 gal tanks) the valves in the back, and it lifts/stays up just fine, and I only run my compressors to 145psi.
