lower control arm crossmember???
I
F
freky1
once you have drug through the cross member or hit something and bent the crosmember mounts what do you? time to rebuild. well lets see some pics of wht you have done to replace these old worn out or broken parts
F
freky1
hum nobody has pics?
standardbyker88's avatar
standardbyker88
hell, mines static dropped and i bent it. figured id just replace it and porta power the frame wider if need be. then do my suspension work if need be and realign the truck.
F
freky1
I GUESS NO ONE DRAGS THERE YOTAS ON THIS SITE
ahab's avatar
ahab
I dont drag my toyota cause its on jacks in my garage. I Think alot of guys just replace it with a thick wall peice of square tube that is the correct size for replacement. Hope this helps.
phatedscustoms
i had a yota a few years ago and drug mine to the point to where i had drug thru the bolts that hold the cross memeber on and the cross member fell off so i made the difficuly decision that involved me not giving a shit and didn't bother replacing it. worked out pretty good for me. that desicion might not be for everyone tho.
