offsets??
offsets??
lowridenmazda
i need to know the stock offset and backspacing for my 89 b2200. also i need to know who is runnin 22's with 2wd sheetmetal cause i cant figure out hoe to get past the bodyline cause my z71 wheels with 205 55 16's rub and i need a 3 inch bigger tire to lay out without wastn lift.
mazberrydelight's avatar
mazberrydelight
i thought you already lay out on 22s?
lowridenmazda
i can lay out on a 28.5inch tall tire. the same as a 245-30-22 is just cant find wheels to tuck. so im tryn to get some opinions
scotto79
have you thought about narrowing the front clip?
lowridenmazda
the fronts not what i'm worring about its the back. i've got a cantilever and everything is welded on the rearend and i really dont want to mess with narrowing it
lowridenmazda
i found a set of 22x8 wheels i just need to know what offset people are running on a 2wd bed with a stock rearend to clear the upper bodyline.
dssur's avatar
dssur
unless they are custom built, I doubt they will fit. With an 8 inch wide wheel you will need at least 45mm offset, more if you are bodydropped because like you said, the body tapers in at the top.
sorry. narrowing the rear or buying custom wheels is the only way. if it were easy or cheap there would be a thousand mazdas on 22's, not just a couple. good luck!
