taco suspinsion
taco suspinsion
jdozier1279
i know its a repeat, but i cant get search to work so please help. i have a 99 taco and need to find the best way straighten up yhe front tires and fix the bump ster issue. controle arms, spindle, or both or is there a cheaper way
jdozier1279
some one please
dragnlow's avatar
dragnlow
Hit up Bio Kustomz or the Ask Max thread on here he can help on all that you mentioned
doulovemins's avatar
doulovemins
how big of rims are you running? and how low do you drive it. depends on how your ride hieght is set up in front. its caused by bumps in the road or interacting with improper length or angle of your suspension and steering linkages they can be adjusted to your ride hieght but to some degree bump steer will be there unless you set it to a certain hieght and always ride that hiueght. as far are your tires go im assuming you mean they are toed in or out. Building a hiem steerin link will correct this to some degree hope this helps
jdozier1279
18 inch wheels,plan on z ing the frame and stock floor but right now yhe chamber and toe are awful and bump steer is rediculus at all highhts but gets worse the lower you go
jdozier1279
is there a web sit for bio kustomz
Tacon19s's avatar
Tacon19s
This is a topic you can find on alot of sites. Like douloveminis said, it depends on what size wheel you wanna run, how often you drive it, and everything else. I wouldnt advise flipping the lower balljoints..it increases the bumpsteer. And dont even think about flipping the tierod... You will have a mess. I would use 2 or 3" spacers between the spindles and ball joints. The best thing made for a taco are the drop spindles made by max at Biocustomz. Call him and he will hook you up.
ahab's avatar
ahab
Dont z the frame. There is no reason to. The front will lay flat without a z. Mine did.
wileypdf's avatar
wileypdf
max makes his spindels to work with 18's or 20's specifically. Its just like flipping the balljoint and adding spacers to raise the hub above the lower control arm. but what max does is eliminate the bumpsteer problem and the upper ball joint binding problem that some people have seen when trying to lay on 20's.
I got a set and they are so sick.
Tacon19s's avatar
Tacon19s
x2....no need to Z!! people swear up and down you have to...mine layed flat also.
