ways to fill clutch cyclinder
jsnpdy22
I relocated my clutch master cyclinder, but there isnt any room for the reservior. Was thinking of putting a tee on the front driver side brake line and running one of the lines to the clutch cyclinder to fill it. The cyclinder already has a threaded fitting on it where the reservoir use to fit. A brake line would thread right into it. Anyone know if this would work?
ahab's avatar
ahab
You cant use the brake line because it will already have pressure from the pedal. you can put a nipple on the brake res and draw from that. As long as that res has enough fluid in it.
bodydropped85's avatar
bodydropped85
running a brake line to it that goes to the brakes wouldnt work.
jsnpdy22
I didnt think it would work because of the pressure. I found one that would fit. Thanks for the info.
