Body Drop Clutch Help?
brian@illusivefabrications.com's avatar
slammedxonair's avatar
slammedxonair
well were trying to get my buddys toyota finnished and were now running into issues with the clutch. we had made a bracket to relocate everything after the body drop but the problem is we want to use an external fill resivoir (sp?) now. i was thinking about maybe using a ford clutch setup because it has a line to the fill cup. what are you guys using to finnish this task? its a 1990 i think. thanks
slammedxonair
any pics would also be great!
9
94NissanLaysDoor
If you are running an external setup...I would try a setup off an S10. (Like a 90)
Ford uses a hard plastic line and clips...GM uses cheap rubber hose and hose clamps! (Much easier to work with)
9
94NissanLaysDoor
Normally i see the stock master replaced with an old style like 87toyota (Its shorter) then its recessed in the firewall
se7ensynz's avatar
se7ensynz
i used a clutch mastert cylinder off of a honda civic and it worked out great on my toyota - they have a remote mount resevoir that uses a rubber lin and can be extended as lon as the resevoir doesn't get mounted lower then the cylinder - and its shorter the the stock yota one as well
slammedxonair
what year civic? thanks for the info
drgn91yota's avatar
drgn91yota
on my 91 toyota i have tubbs for twentys bodydropped quarter inch from the door and i moved the whole clutch cylinder insde shortened the rod that connects to the pedal and made brakets for the pedal off the colom bar and ran the clutch line threw the firewall then made a crazy pedal
slammedxonair
yea we had origionaly just moved the whole thing under the dash but he wants an easier way to fill the cup like under the hood. does anybody else have any ideas or pics i know theres alof of body dropped yotas out there. thanks
m_i_zombie
I have mine under the cowl on my 87. I used an s-10 reservoir that feeds straight into the stock aisin mc. After the system is bled there shouldn't really be many times of topping it off unless its leaking or needs to be replaced.
