What size 24" tire???
bhrestaurantequipment@verizon.net's avatar
Jcfreeman0's avatar
Jcfreeman0
275 (30.5") 285 (30.75") or 295(31") / 30r24 tires????what is everyones opinion on this?
i know a 275 will fit up front. I could get them mount them up and be done. i think a 285 will be close but i might have a rubbing issue and i think i will have to work a little to get a 295 to fit. the major concern is the width of them. my booster is close to my wheel and my tubs are close. my plans are to buy two because i know they will fit in the back and check them up front. should i just get 275's all around? 275 up front 285 or 295 in the rear? 285's all around? let me know what you think.__________________
loudciv's avatar
loudciv
Edited: 5/29/2008 4:03:57 PM by loudciv
thats a 275/30/24 on your wheel. slightly less stretched looking that what you have now.
tlw32882's avatar
tlw32882
i say run the biggest you can fit. either way you look at it, anything bigger than what you got now is going to be better. its going to get expensive to keep fixing and or replacing wheels and tires. just my opinion.
tlw32882's avatar
tlw32882
any body else got experience with rubber bands. im curious to what people think of there 275/30/24 tires. do you wish you had more side wall or do you not have any problems with pot holes?
wstewart58's avatar
wstewart58
with a 275 anything more den a reflector in the road is gona bend a wheel or pop a tire. .in my opinion it would worth a lil extra work 2 run a 295/30/24. .i have 305/35/24's on an 03 silverado with a 4/6 drop i no jus a static drop but it stil bottoms out like a b*tch wen i got a bunch of people in the truck
