Ask A Pro \  panhard?? again
panhard?? again
Ask A Pro Q & A
views 187
replies 3
jealousonezenvy   +1y
can i run two pshort panhard bars on top of axel? i have no room in back since im running reverse 4 link. or can i run a bar thats 3/4 of rear end?
willie_wonka   +1y
You can't run two panhards on opposite ends as they will fight each other through the range of the suspension. You can run a shorter bar, but keeping the axle centered will be a pain in the ass. Best bet probably is to triangulate your four link, its usually alot easier than a panhard because the axle stays in the middle through the suspensions travel. Hope this helps.
BioMax   +1y
I have seen a system that used a watts-link, but the link itself was turned on its side and run below the rearend. Maybe you could do the same, but mount it on top of your rearend?
jealousonezenvy   +1y
max see my profile pic of my panhard it goes halfway across rearend no play from side to side and works awesome
