Mazda Trucks \  air bag electrical set up??
Mazda Trucks Make Specific
views 194
replies 1
following 2
jealousonezenvy   +1y
1)Where is your pressure switch wire wired into?2)Wheres your power wire to your control switchbox wired into?3)When running digital gauges wheres the power wire plugged into?
I really need some help
mitsu94   +1y
ur pressure switch is wired 2 ur comp relay ur switchs should be wired 2 a constant power source such as battery or fuse that is constant power gauages should be wired 2 switch power like a fuse that looses power when ignition is off suicidedoors.com has wiring diagrams for the pressure switch and relay
