Removing 04 Chevy Door panels
coptic120
Before i go out in the heat anybody want to save me some time and run it by me real quick where the screws/clips are on an 04 Silverado door panel?
chevyman992002
I'm thinking the '04 panel is the same as the 99-02. If that's the case, you're going to have screws behind the sliding lock, one right under the arm rest, and another on the very bottom front corner...pretty much right under the door speakers. Then just pull the bezel off from around the door handle and lift it straight up and off. There are clips that actually snap into the door, they just slide down into the holes on the door and the screws hold it in place.
