baggin an 03 trailblazer
riddinlow99@charter.net's avatar
riddinlow99's avatar
riddinlow99
me and a few friends are baggin an 03 trailblazer and have been looking for some that have been done and have come up pretty much empty handed. Im lookin for how anyone has done the front setup i have an idea on how I would like to do it but would like to see what suggestions are out there for the back were just goin to notch it and run bag over axel the end goal here is to get it to lay frame on 22's thanks for any suggestions
nopinch's avatar
nopinch
There is a guy here in tulsa that has a trailblazer that lays on 22s, he has spent a few years and a TON of fab work to get it to lay. He had to use cylinders up front beacuse i guess there isnt enough room for a bag
soccorjimmy's avatar
soccorjimmy
GO over to trailvoy.com there is a couple write ups plus the guys are on their alot so they could help out. JIMMY
tealchevy's avatar
tealchevy
going to be doing the wifes this summer. Bags will fit but only a small one in the front. Like a colorado set up. Lots of relocation under the hood and lots of door jamb work on the rear doors. what size tire are you going to run?
ahab's avatar
ahab
Check out the profile "uneek1" This is my brother mikes envoy (envoy and trailblazer have the same suspension) there are alot of pics on how it was done. There is more than enough room for re7 bags. The front is cake the rear is the problem. Expect to cut the floor out from the rear seats back for clearance. Door jambs and doors will have to be cut with runing 22s with 255-30-22. Anything bigger and you will have to relocated rear door latches. Keep that in mind. Let me know if you have any other ?s.
riddinlow99
thank you all for the info I was hopeing to get away without cutting on the rear for the wheel tubs I planned on having to cut through the floor for the notch. i might talk him into runnin 20's if we can get away from cuttin in to the door sills.
riddinlow99
andrew do you know if there are any more pics on how he did the front I see in the profile he has re-8's all the way around just wondering how he mounted them up thanks
Boilermaker_744
Any updates? Did you ever do it?
