Chevy 66 c-10
F
Chevy 66 c-10
J_ROCK
Ok I was wondering if anyone could help me. I am bagging my 1966 c-10. It is a step side and i'm want to run a 305/30/26. Or possible a 24?
- will I need a super c-notch or just a small bolt on. since it is a step side? I'm going for the hot rod look but with just bigger wheels.
WF
Wicked Fantacies
Well you say your going for a hot rod look. That wouldn't be all the way to the ground unless your meaning bigger wheels out back and smaller in the front while laying frame. I take it no body drop? You going to need to measure the height of the axle whith the size tire your going to run and measure if the frame is laying on the ground how much further the axle would be above it then youll know u need x amount of a notch. You may squeek by with stock outside step side fender of course the inners will have to be cut that would be if your only laying frame with no BD. but even then thats real iffy because im not sure of the height. I'm at work so I may not have thought through this all that way either.
J_ROCK
Ok i'll measure all that and yeah its going to be real iffy I just want it to look really good with out a year long project. just something to crusie around in. Thanks for your help anymore thoughts let me know??
s10
last post by baha +1y
