90 yota bagged with 20x9... brake problem any help please
2be1off
i have a 1990 toyota s cab 22re. i bagged the front and tubbed the firewall and had to relocate the clutch and i extended the brake booster to the front of the tire by the cor support. the problem im haveing is i bleed the brake all the wy around it builds up pressure fine but if i let it sit for awhile like an hour or so theres no pressure till i pump it. any ideas like brake cylinders or zurk fittings or the paper gaskets betweenthe booster and master??? please help
nryota
got to be some air in there somewhere. thats all i can think.
cookiemonster13
it would not have anything do with the brak booster or the paper gasket between. if you bleed it and it feels really good first touch after that. then later it is basically dead again with out pumping 2 or more times to get a solid pedal i would say the master cylinder is going bad. you need to pull the rear brake drums and check the front rotors to make sure there is no leaking fluid. if you find fluid on the backing plate or on the rotor you have a bad caliper or master cylinder. good luck, if you dont find any leaking fluid the amster cylinder is bad
2be1off
ive checked the wheel cylinder all lokks good i throw a new booster on it soon. if any other ideas come let me know... will a 89 yota v6 master bolt up and work????
unusualfabrication
Sounds like a bad master cylinder to me.
MIOTCH616
also jus another idea. if the rear shoes are not adjusted properly the pedal will feel spongy til you pump it up. better to check the free stuff first b4 dropin money on a new master cylinder
2be1off
i have an extra master. but defintly the free stuff and easy first thanks for all the input.
FreelandKustomz
Its deffinilty the master cylinder. Thats exactly what happens they go out.
lovebledhate
ok how did you move the booster forward????....im having that problem now....my wheel dented my booster and ima put a new one on and i want to extend it out....pleas eexplain how you did it...mine is a 1991 22re
