moving clutch master cylinder, how to...
ccscotty06@netscape.net's avatar
laydsuzu's avatar
laydsuzu
anyone know the steps in doing this? having to redo the geometry of the pedal itself? i need to move it up to clear 20s with a 35 series tire. ive seen pics, but i need to know what to do....but again pics are more than welcome
bodydropped's avatar
bodydropped
try the s-10 fourms scooter someone over there might have done it already
laydsuzu's avatar
laydsuzu
someone on here must know, and be able to explain it better. bump
bdydrp97s10
just drill4 new holes for the smaller booster then one hole in the center of the four holes for the push rod of the new booster... i would imagine the center hole would have to be at least one inch in diameter, but just make sure the rubber boot on the pushrod can fit into the center hole to prevent water leakage..
and you will have to cut or bend teh rod from the brake pedal to meet the pushrod coming through the firewall.. its handy if you know how to weld in thks step..
just when your setting up the pushrod and rod from the pedal make sure the booster pushrod is all the way in. you dont want the pedal hitting the floor before the pushrod is all the way in
laydsuzu's avatar
laydsuzu
no, not for the brake booster, for the clutch resivoir
bdydrp97s10
sry i didnt see the clutch.. but the steps would be similar.. my friend recessed his clutch master back into the fire wall on his sonoma.. i think he did it with a piece of pipe recessed back into teh wall, and he moved it up i believe
