which sending unit to use for carb in a b2 tank?
dan48p@netscape.net's avatar
dan48p's avatar
dan48p
ok, i have a bronco 2 fuel tank and am using a 600cfm carb on a 302.i have the factory fuel pump and sender from my 92 3.0 ranger that fits in the tank. i can use that with a return style regulator and then one fuel line going up to the carb.
i was wondering if there are any factory fuel pump/sending units that i can use to get lower pressure and no return line. i thinking maybe something from an 80's bronco 2. i guess in 88 the 2.9 bronco 2s used 2 fuel pumps and the one in the tank runs 4-6 psi, and then there is a high pressure pump outside the tank. this sounds low but would that be enough fuel for that carb?
i suppose i could always just get a unit out of a returnless ranger and regulate it with only one fuel line running up front.
you guys have any suggestions on which piece to buy? i want to use stock parts (well, stock for something) so that i can easily get a replacement if necessary.
thanks
bodydropped85's avatar
bodydropped85
or just get the sending unit for a carb'd bronco II. i think its a direct swap. the in tank pumps on the gen Is are designed to just get the gas out of the tank not push it to the motor. i would use the stock 92 pump and put a pressure regualtor at the carb.
tuckin eh's avatar
tuckin eh
just run the stock in tank pump to get it out of the tank and run an in line pump with a regulator under the hood or along the frame. it's what I did on my gen 1 ranger with the same setup (5.0L holley 600)...but the stock ranger tank (was a 2.9L)
SunsetRanger's avatar
SunsetRanger
Edited: 7/23/2008 12:55:37 AM by SunsetRanger
carb'd bronco II tanks have a different pump and opening. Its actually smaller then the Fuel Inj models...
