Installing fuel cell in 92 pup questions
W
W
waggscj
What all do i need for the fuel cell to put it in my truck? I got the 2.3L engine so you know. I pulled the old one cause dude that had it before me cut the crossmember out when they notched it. So, I'm just gonna do the cell. It has 3 lines and the breather tube for the fill part but most ones I've looked at only has 2 spots for hose and the breather. So yeah any help would be awsome. Thanks in advance.
infamous_dough_boi's avatar
infamous_dough_boi
depends on a carb motor or fuel injection?
W
waggscj
its got a carb
wikedmofo's avatar
wikedmofo
or you can get an after makert fuel pump like holly black it pump 6psi run a hot wire to the pump run the hoses to the carb and return back to the cell with a regaluter i did that to mine pup
ExplicitDesignz's avatar
ExplicitDesignz
On the 2.3, isn`t the fuel pump is located on the motor?
eatinpavement's avatar
eatinpavement
the 2.3 with a carb does have a mechanical fuel pump on the head of the motor. any fuel cell should do fine or you can just make a bracket off the side of the notch if you really wanted to keep the stock tank underneath.
eatinpavement
if your running a fuel gauge make sure to get one with a 0-90 ohm sending unit.
Related Discussions in Isuzu
