Full Size Truckin General \  hood from a 67 c-10 on a 70?
views 307
replies 5
following 6
Von Drag   +1y
pretty much just what it says, will the hood off a 67 c-10 fit on a 70?
bdydrp97s10   +1y
im sure they will..check out 67-72chevytrucks.com.. theres alot of useful info on there.. and a really good parts forum.. but yes im pretty sure they will fit, but you may have to change the hood latch..to a 67-68 latch
leftcoast66   +1y
Definitely check out 67-72 but if I remember right, the fenders are different and you have to swap those with the hood since the front end is different. I know I've seen the info on 67-72chevytrucks
low downin   +1y
fenders are definitly different. if you want the grilled to to you need a radiator support to as the lights on the later models are about 2 inhes higher. hope this helps,
KNDAlow   +1y
yep, you have to get everything, hood, fenders, core support. i just did the swap on mine from a 71 to a 67.
KEEF   +1y
Im running a 67 hood on my 72 Suburban its definately not a bolt on affair. The hood has to be shortened 2 inches to fit
