Under Construction \  1990 S10 Project
1990 S10 Project
Under Construction General Discussions
views 457
replies 9
following 7
onelow96cs   +1y
Work is being done by Unusual Fabrication. Everything was built in house. 4-link, gussets, bungs, bag mounts, all the tubing bent up, cross members, fuel cell. Frame holds 5 gallons of air. York 210 EDC will keep it full. Using 5150 12" shocks with reservoir. Never had the motivation to make one of these but since my truck has been on a steady pace figured what the hell why not. Pictures will be updated as it goes.
1lowtaco95   +1y
looks good man. did you figure out about how many gal. of air your frame would hold??
onelow96cs   +1y
I myself didn't. But the builder Unusual Fabrication calculated it up.
smctoy   +1y
very nice!!
ixenn   +1y
thats easy though LengthxWidthxHeight so if the frame was 5 ft - 60inx2.624x1.624 this assumes a 2x3 square tube with a 3/16" wall
fatboysS1O   +1y
frame tanks are always cool.
thatsmydawg   +1y
usually cool till you drag threw it or a weld rots away then your fucked
onelow96cs   +1y
The measures were taken to have a nice reliable system. Gussets to spread the load to reduce stress on the joints. Water trap to keep most the water out. Por15 on the frame. The section of the frame that holds the air don't touch the ground and I don't drag so I am good there. Something does break in the future hopefully they still make steel and welding wire. Not trying to be a dick but I do think realistically.
ixenn   +1y
Edited: 6/16/2008 1:09:20 AM by ixenn
Have a little faith in it haha
my frame is the tank too and theres a 1/4 hot roll bar welded to the bottom of it.
tuckinlugs06   +1y
i not a big fan of the s-10 but your square body is one i like
