Mini Truckin General \  has anyone fixed a walkthru?
views 284
replies 12
following 12
trashed   +1y
i just picked up a new truck and it has a full cab cut and i was wondering if anyone has messed with fixing one? is it easier to use a rear cab skin or build your own?
smctoy   +1y
I personally never had one, but a buddy of mine did a walk through on his 88 Toyota, then when he decided to sell it he used the back wall out of another truck & re-welded it back in.
tuckinlugs06   +1y
just weld some flat sheet metal back on same as smoothing the back wall
trashed   +1y
not really, you have to do something about the back glass.
standardbyker88   +1y
oh, he did a full walk through with a topper? id say get a cab. or cut the stuff you need off another.
ixenn   +1y
might as well chop the top..
aon-teach   +1y
Sounds like a roadster to me, or get a donor cab
FievalFON   +1y
ACTUALLY YES...I DID A WALK THRU ON MY 88 ISUZU PUP, REALIZED IT WAS RETARDED AND SIMPLY HIT A LOCAL JUNKYARD, REMOVED THE REAR SECTION OF THE CAB AND RE-INSTALLED ONTO MY TRUCK...NOT AS MUCH WORK AS IT SOUNDS I PROMISE...BUT OTHER THAN PURCHASING A NEW CAB I BELIEVE ITS THE BEST AND MOST CORRECT WAY OF DOING IT, BUILDING A CUSTOM WINDOW FRAME ISNT SOMETHING I THINK U REALLY WANT TO BE MESSING WITH, JUST MY OPINION THOUGH, TAKE FROM IT WHAT U WILL.
NIGHTMARE73   +1y
SELL IT AS IS AND CUT YOUR LOSS'S !! HELL YOU MIGHT GET MORE FOR IT THE WAY IT IS WITH THE WALK THROUGH
loudciv   +1y
as said above brace it up & sheetmetal it smooth. its really not that hard to create a lip for the window gasket to seal on.
