Rough Idle and backfire
groundedwatts
So everyonce in awhile my 94 toyota will start idleing rough like it wants to cut off and i'll give it some gas and it backfires a little bit. I checked my plugs, my air intake, my vacuum lines, my fuel pump and filter. That all is good.
Is it possible a weak battery could cause some of the electronics on the truck to not function properly thus causeing the above situation?!? I've got an optima red top and have had it about 2 years. Haven't tested it yet though...lol.
what do you think?!? any suggestions?
standardbyker88's avatar
standardbyker88
what about the voltage regulator? make sure you are getting the right voltage out. otherwise the fuel pump will work, but at less psi making it run out of gas and stumble. and is it an EFI truck or carb?
groundedwatts
EFI, sorry for not mentioning that!
tuckinlugs06's avatar
tuckinlugs06
mine has been doing this also...
the501clique
bad timing?
