truck action
Block it up first,then air it out so the bags are down,then dump the tank,then you can pull the air lines.
If you use check valves between the fill / dump valves,you can air up ,leaving the bags full ,then dump the tank & remove lines. I set mine up this way with hard lines going into the bed floor( into bulk head fittings) then into push to connect fitting,so I can pull the bed leaving pumps/tank ,ect. in the bed!!
