Ask A Pro \  Narrowing track width
Ask A Pro Q & A
views 443
replies 7
following 7
draggindakota   +1y
Max, if I were to narrow the front track width on my 93 Dakota, say 2 - 2.5" overall, would that have many adverse effects? the wheels I really want to run don't have the right offset to tuck once it's body dropped. I'd rather narrow the whole thing than just shorten the control arms. Thanks.
BioMax   +1y
Narrowing the frame is far better than shortening up the arms, it should have a very minimal effect on driving.
CadeCustoms   +1y
I was gonna ask you the same questions max in regards to my dually. I want to narrow the front and when i become rich have u build me a set of drop spindles for it because i dont really want to raise the uppers
NR RailnPup   +1y
i used a 86 yoda clip and it nerrowed mine almost 3" in the front
low f350   +1y
I just narrowed the front of my frontier 2". Make sure you will have enough room for exhaust manifolds/headers and steering box. Also, you will need to make sure you have enough room to shorten your motor mounts.
draggindakota   +1y
It looks like there will be enough room to make some motor mounts and clear the exhuast. I have to measure to be sure.
What is the yota bolt pattern? It's 5x4.5 right? If it is I moght look into that, since I can just swap the rear end for an older 5 lug dakota.
standardbyker88   +1y
yeah, thats yota pattern. if you do that, i would try and retain the rack and pinion though, they look cleaner. i perfer them anyways. if you dont though, i want your old rack and pinion if its not messed up. lol.
thacru78   +1y
I narrowed the track width of the Dodge 5 inches. I used all the factory specs for the front suspension, just made the frame 5 inches narrower then I used a custom rack and pinion to dial in all the steering issues you get with narrowing the track width.
