Under Construction \  supravan whats that
supravan whats that
Under Construction General Discussions
views 317
replies 9
following 6
supravan   +1y
who wood b tha best 2 holla at 2 help me with the wiring on my 88 turbo supra motor n my 89 astro van
jsondrops   +1y
someone japanese! seriously though,is it a 2j? out of a supra here or japan?Igot a buddy thats wiring a 2jzte from japan in his supra and the harness has to be stretched because it was out of a rhd.badass van though when you get it done!also i work at a yota dlrship so if you need any info or parts i'll try to help! gl bro
supravan   +1y
its n a supra now it runs and everything and nope not a 2j its the tm gte motor its from here and thanks im hopin 2 have it done by slammin next yr
jsondrops   +1y
cool,cant you just gut all your factory wiring and use the whole harness and comp from the donor car?
supravan   +1y
well i am goin 2 do that but i want my blinkers and head and tail lights 2 work also, not worried about gauges cause all of them will b aftermarket i just got 2 find out what i have 2 have and what i dont need on tha supra motor
lowromigo   +1y
You had that Astro Van at Scrapin the Smokies right?
gimp5561   +1y
try WWW.SUPRATRUCKS.COM
KEEF   +1y
Daniel just keep the wiring for running the engine and controlling it seperate from the vans wiring and you wont have problems buddy.
aa taco chris   +1y
yessir as Keef said... just run 2 different systems/harnesses and you'll be fine. You can even use both fuse boxes if you have too... it'll be the easiest way.
supravan   +1y
i did have it at smokies show and keef thats easier said and done me no wiring guy unless it steros
