Mini Truckin General \  lug pattern: 5x120mm and 5x120.65???
views 512
replies 5
following 5
no1lowr   +1y
anyone know if a 5x120mm wheel will fit the 5x120.65 lugf of a covette, im using the front and rear suspension of a 2001 one vette on my ford and cant find any good lookin wheels in the 5x120.65, ive asked around and gotten mixed results from tire shops about them fitting. also can i buy a 5x4.75 rim??? im kind of lost on this.
no1lowr   +1y
bump
cookiemonster13   +1y
5x4.75 is 120.65 exactly. as for using a 120.00 wheel i am not sure. it should with the right lug nuts and studs.
cookie
ahab   +1y
A 5x120 will fit on 5x120.65 and vice versa, but it will bend the studs and most likely the truck will viberate like crazy. I would highly not recomend this. Most reputable wheel companys will not even sell you wheels if your intention is to do this. It just like all the guys running 5x114.3 on caddilacs with 5x115. i will fit but will eventually fail.
gravity5   +1y
Get forged wheels, they make any bolt pattern offset and size you want.
unusualfabrication   +1y
Bad idea if you ask me, clearly two different diameter patterns.
