rear brake line
rear brake line
nvrhapy avatar
nvrhapy
i got a 92 dakota and i noticed the rear break line is broke whats the easiest way to fix this
bigjon avatar
bigjon
replace, autoparts stores sell lengths of hard line all you do is bend them up. they Have the ends already set up.
http://cgi.ebay.com/ebaymotors/JEGS-63041-Stainless-Steel-Brake-Line-3-16_W0QQitemZ170231751638QQcmdZViewItem
nvrhapy avatar
nvrhapy
the line goes all the way from the front to the rear i would have to replace this whole line? i figured there would be something i could do to clamp thses together?
sadexcuse4s10 avatar
sadexcuse4s10
i don't think you want to try to clamp a high PSI brake line together man.
just get yourself a couple AN fittings and a union. Then learn to use a tubing cutter and double flare tool.
everything can be bought at the parts store
thacru78 avatar
thacru78
You can cut the line, buy a short piece of hardline and the couplers. Then rent a flare tool from autozone or Oreilly. I bought a flare and bender the other day from Oreilly for less than $20. It's really easy to work with. They sell the couplers there, and i'm not talking about a compression fitting, i'm talking about flare fittings and flaring the brake line.
lucky_brew avatar
lucky_brew
duct tape!
seriously, just buy a piece w/ couplers and bend it yourself. make sure you buy/rent the bending-flaring tool though - makes life a lot easier!
jsondrops avatar
jsondrops
napa sells brake line that is bendable by hand! its polymer coated *sp* hahaha
but its really easy to use
good luck and let us know how you fixed your problem!
nissandoordragger avatar
nissandoordragger
that looks like a e brake line to me and if it is you dont really need it but if you want it you might have to replace the whole cable
