How to clean a gas tank
sheffieldced@gmail.com's avatar
Tacon19s's avatar
Tacon19s
Its time to throw my gas tank back in and I need to know what to clean the inside of it with. its been sitting with the pump in it and NO gas in it for about 3 yrs. What do I do? Should I just pour some gas in it and let it sit for a couple days then drain it and dry it out?...please help
Uncle Fester's avatar
Uncle Fester
If I recall correctly you put some gas in and a chain of some sort. Get the chain moving around to help knock off anything that might be in there. I am sure someone else can chime in with a better idea.
twistofcain's avatar
twistofcain
i use some purple power and water and then blow it out with air
Tacon19s's avatar
Tacon19s
thats it?^^
twistofcain
well u have to slosh it around and drain it then blow it dry
Tacon19s's avatar
Tacon19s
purple power takes care of all the old junk in there and gets it ready for new gas?
bodydropped's avatar
bodydropped
eastwood sells something that should clean a tank if my memory is correct
oneup's avatar
oneup
I used muriatic (SP?) acid and sloshed it around for a few then poured it out and used that tank liner shit you get at oreilly's I think its made by POR-13 I can't remeber its a liner keeps it all good.
Tacon19s's avatar
Tacon19s
thanks guys, I think im gonna go with the eastwood kit. Everything I have bought from them has worked pretty good.
