Interior \  a pillars?!?!?
a pillars?!?!?
Interior Q & A
views 331
replies 2
following 2
slamnscotte   +1y
i just got a y2k jag s-type and the a pillars are falling apart. so how do i pull those off to redo them? any help would be great thanks alot.
slamnscotte   +1y
bumpity bump someone please
beloved   +1y
im not to familiar with the a pliiars of your paticular jag but you may want to start with
any visable screws. it will might make it easier if you drop your sun visor, if the is a panel that runs from you a pillar to your b pillar that will def need to be re moved if there is a speaker grill at the bottom of the a pillar you may want to pull that off to make sure that there are no screws
in side there. once you are sure that there are no more screws then your gonna wanna pull on it. it might come right off but it might need to side up first. just use equal force and take your time. if you can post a picture of the a pillar along with the suronding panels i can probaly give you better advice . hope that this helps you.
josh
