switches...
switches...
granth avatar
granth
Edited: 7/2/2008 12:04:12 PM by 72bumpside
what amp rating do switches need for our air setups? Just need a heads up on some details, so I don't order the wrong thing.
oh and i kinda want some push button ones. I don't want a box though!
LowOrange88 avatar
LowOrange88
I would have to make an educated guess...and say to match the amperage of what ever valves you are using, since basically the switch is what actuates your valves. The manufacturer of the valves should have that information available.
cookiemonster13 avatar
cookiemonster13
rewire the valves to where the switch is the ground and you can run any kind of switch you want with no worries.
pearldrop avatar
pearldrop
The switch would still need to be rated for the correct amperage whether you are running them off the positive or negative. But there isn't much to worry about with valves. They draw nearly nothing.
