Cruise control no workie
jasoncampbell1180@gmail.com's avatar
jcampbell1180's avatar
jcampbell1180
The cruise control recently stopped working on my
surfrat1960
Sometimes the cruise servo under the hood will go bad! or simple as the fuse!!
someotherguy's avatar
someotherguy
That '88 burb has the old vacuum style setup as used on all the squarebody trucks. Fuckifino how to work on 'em.
A real common issue on the later style with the electric motor cruise servo thingy is the brake switch goes bad. Multiple contacts inside the switch, and the switches are pretty cheaply made; you can still have working brake lights but have nonfunctional cruise because that set of contacts has gone bad. They are little leaf switches and they break off and fall over...stuck on = thinks you're stepping on brake, disables cruise (AND torque converter lockup!)
Richard
jcampbell1180
Hmm. Okay.
I'll start there.
jcampbell1180
I figured it out. The linkage between the cc diaphragm and the throttle body had come off somehow.
comegetsome's avatar
comegetsome
richard always amazes me....man i bet you know more about the chevrolet trucks than the people who designed it....
jcampbell1180
someotherguy
Smarter or dumber than the guy that didn't just look under the hood first to find the linkage fell off...hope you stuck it on there with something better than a bread twist-tie.
Richard
jcampbell1180
LOL. You know what was weird about it? The little metal bracket on the diaphragm 'broke'. Like, the linkage wore through it, or something.
Odd.
someotherguy
Oh! Well in that case...
I suggest bubble gum.
Richard
