s-10 doesnt start
LT608@yahoo.com's avatar
s-10 doesnt start
L T's avatar
L T
My buddy's 96 s-10 wont start after he finished paint and stuff. It gets gas all the way up to the shcreider valve by the injectors but wont start unless gas is poored directly into the throttle body. Disconnected ground etcc...? any ideas would help, we have a show today.
9
92zuzuman
Does gas squirt out of the test port on the fuel rail or just kinda dribble out? If it doesnt squirt out ur not gettin fuel. My 4 cylinder 94 s10 gets 42 psi at the rail i believe.
slmd02s10's avatar
slmd02s10
i just went threw this with my 02 had to have the VATS takin out of the computer
DILLARD's avatar
DILLARD
I went through the same thing and all mine was just a fuel pump relay changed for $20 and fired the first time.... "located on the firewall"
Hope that helps
Dragthatchit's avatar
Dragthatchit
check the ground located in the tailight harness plug at the rear drivers frame rail, the ground wire there is for the fuel pump, just had the same problem while we were changing a bed for a guy!
disfiguredS10's avatar
disfiguredS10
Check the relay for the fuel pump, my relay was clicking but i was only getting 4 volts out of it. swap it with a known good relay. The ac relay was the same part# on my s10
