geo metro brake booster
ricbarnes777@hotmail.com's avatar
Navara777's avatar
Navara777
are geo metro brake booster's universal fitting?
get twisted's avatar
get twisted
you will need to explan more what you mean i have one on my hardbody but i had to use the metros resivor also there is a pic in my profile before i swapped resivors but the brake line fittings were the same you will need to remove the spacers under the dash on the firewall and redrill the two holes on the pedal bracket to bolt up but its a simple swap and works great
Navara777's avatar
Navara777
OK, i just need to know if you need to get a geo to fit to a hardbody (D21) specifically or are they all the same? And why do i need a different resivoir?
johnz
ok why not get a hydroboost from an awd astro better braking by a million and just as much as the metro from a junk yard
you can move your factory booster over and modify the rod. it is what i did on mine. i lay out on stock spindles with 18's, bodydropped.
Navara777's avatar
Navara777
Whats a hydroboost?
Whats a awd astro?
Sorry im from New Zealand have all different names
lowrod63's avatar
lowrod63
The Geo Metro will work fine with little modifications or make a spacer, I used a 720 nissan spacer on my impala.
nissandoordragger's avatar
nissandoordragger
i got a geo booster with the nissan resivor all you do it takr the resivor off then unsrew the adjusting srew in side it and go to the hardware store and get on that is longer then put it in it works great also
