need help
need help
burnsy
was wondering what all motors are a derect swap for the 92 toyota pickup and will a nissan hard body motor bolt right up ? just picked up the toy and had a blown motor
cookiemonster13's avatar
cookiemonster13
20r 22r 22re, there are kits to bolt other motors in there such as 2rz and 3rz and 350 chevy motors.
boooghar's avatar
boooghar
if you use a nissan engine for example you have to go thru the hassle of mating the old wiring harness with the nissan harness (assuming you are using a efi type engine) if you go the V8 route then you hafta deal with the extra weight issue, engine mounts, cooling ie larger radiator then routing a whole new exhaust and by that time the amount of money spent would be more than buying a stock replacement crate long block
just my 2 cents
tuckinlugs06's avatar
tuckinlugs06
im gonna swap a 3 cyl geo motor..hell yea
burnsy
thanks for the info just bought a new project and has a blown motor not planing on goin with the v8 becdouse of clearance issues
crzyone1013's avatar
crzyone1013
I saw an awesome intake for the sbc's the other day at work in the new issue of street rodder we are doing at work. it is a marine type intake with dual side draft carbs that sit about even with the valve covers, its a pretty damn good way to get around some clearance issues with the hood.
TwistedMinis's avatar
TwistedMinis
^ Those are cool.
You could always run an LT or LS motor with a dry sump and a 5 speed. You can get them under 23" tall. Believe me, I have it all planned out.
