ok well the taco dash is in
tuckinlugs05@yahoo.com's avatar
tuckinlugs06's avatar
tuckinlugs06
well just got the taco dash in my 93 yota...just sorta in there for now..later will make it fit perfect but need to know what billet parts do that make for it also...and one have a spare nee kick peice ...also was able to use the stock gauges with alot of cuting and fabing...this swap was not as easy as i thought...but here is some pics..and nothing has been painted and is still the stock colors ...but may be paint black for now or wraped not sure on what yet
waynehammer's avatar
waynehammer
kick ass. looks like it came in that truck
tuckinlugs06
next is a taco wheel or a billet one...not sure yet on what i should do cause i hait that one thats in it ...but a stock wheel is to big...might put the tilt colum from my other yota so i can use a stock size wheel..manul steering with this wheel sucks
tuckinlugs06
Edited: 7/11/2008 7:02:29 PM by TuckingLugs05
the thhing that sucks the most is the taco is taller than the pretaco ...and makes the dash taller then the stock dash and make even less room for feet and legs in my truck now..well pass side is ok g/f is shorter and dosnt need the room but on my side with the stock nee kick i would be able to get to the pedals...so mabe a custom fiberglass one or cut a stock one like i did the one for the old dash...and the only peice that will not fit and will have to be heavey modded unless i can move the ing...is that peice that goes around the key..has anyone move a yota pickup ing ?..can the square peice that joins the ing to the colum be cut and moved?
snydecat's avatar
snydecat
yer pre-taco taco is commin along nicely.
smctoy's avatar
smctoy
Looks damn good...Ive been playing around with that same idea, but use the right hand drive unit instead!
smctoy's avatar
smctoy
Oh & talk to Steve at CanDo Specialties...he makes & can make just about anything billet you want or need for that model truck!
lost cause's avatar
lost cause
Look'n good man!
standardbyker88's avatar
standardbyker88
dibs on the old wheel. did it bolt right on or did it need an adapter? whats the diameter of it? how much?
tuckinlugs06
if you want it ill let ya get that adapter ...20 plus shipping sound right?
