Need some more Help with H2 perject?
F
J_ROCK
Ok I found a body! Now I am wondering if anyone can give me some info on a frame that would work under neath it? I know they a 3/4 ton frames but not sure if any other frame could be used? Or is it a single, extended, or crew cab frame?
Any help would be awesome!!Thanks J-ROCK
lucky_brew's avatar
lucky_brew
why on earth buy or salvage a frame? build your own frame! probably be cheaper too...
but i think the frames were from a 2500 series chevy. not sure on the wheel base (extended, four door, long bed, etc) though
hue jass's avatar
hue jass
I always heard tahoe.
scotto79
Just front clip it with something roughly the same track width, then go with a firewall back. That way you don't have to mess with steering and can set the wheelbase at whatever you want.
J_ROCK
Right it is going to have a frame built for it just looking for something to start moking it up with as far as width, lenght, axles, steering that sort of thing?.
J_ROCK
Good idea scott I was thinking of build a frame front to rear but it may be easier doing a front clip cutting it off and using it then build the rest!
J_ROCK
G RANT? Do you know what year tahoe?
scotto79
the H2 has a 69.4" track width, so just look for something roughly that size. You could also get something narrower and run a little wider wheels or have some deep tucking.
J_ROCK
Hell yeah I didn't think about running a wider wheel? Also scott is the from spindle to spindle?
scotto79
Its the track width, from center to center on the wheels.
