Need help finding...body mount material
W
W
WickedBird
Sorry if this is in the wrong forum...didn't really know where to put it.
anyways, i'm looking for the material to make body mounts/body lifts. This is for a custom application and they will be cut down and shaped so I can't really use a kit. I'm looking for the large piece that can be cut down to size. I've seen it online but can't find it again. The type of material isn't a big concern, just something fairly solid and durable that can be used for a bushing.
slammedstroller
how big (tall) is the biggest piece you need?
bigjon's avatar
bigjon
Delrin is what your looking for. can be machined easly
jdm customs's avatar
jdm customs
http://www.mcmaster.com/ you can order any size and hardness(durometer) polyurethane from this site. this is where i get my poly for 4links/motor mounts/cabmounts. not to mention anything else i might need.
W
WickedBird
1.5" would probably be about the tallest.
I need about 10-12" of 3" diameter and 10-12" of 2" diameter. mcmaster.com has what i'm looking for, but i was really hoping for something a bit cheaper. Those poly balls would actually be perfect but a bit expensive as well.
TwistedMinis's avatar
TwistedMinis
Delrin is probably the best bet. Try Aircraft spruce.
Its going to be expensive regardless.
I've started using horse trailer padding for actual bodymounts.
corey0814's avatar
corey0814
i know it sounds backyard as hell, but they didn't (at the time) make a body lift kit for my buddy's pathfinder, so he used a bunch of hockey pucks. they had about the same density as the stock bodymounts & they were easy to put on the lathe & mill down. at first i laughed at him, but it actually worked quite well...plus they're only $2-3 each. they're also about 1.5" - 2" tall if i remember right.
W
WickedBird
I have actually thought about the hockey puck idea...and i'm seriously considering it.
The bushings I am making are for my daily driver. They are a dealer only item and they run about $400 for the set of 4. I'm not trying to be a cheap ass, but the car is probably only worth $1500 and is pushing 200k miles...probably not going to last forever. On top of that, I can't justify that much for 4 bushings.
Now I'm not sure what to do. I don't want to spend a couple hundred and still have to make my own.
