Baggin Fullsize Ram?
slammed94ranger
I'm interested in bagging my 96 ram and had a few questions. From what I've read on different forums and different setups I've looked at, to get the truck on the ground on 22s(what I want to run with a 265/35/22, maybe smaller)I'm going to need control arms and spindles to get it on the ground.
Figured a RE7 up front(would provide a good ride for the v8 truck). On the control arms(if infact I do need to buy the DJM ones), do I just then weld the bag mount onto the control arm? I've seen ARTs CoolRide front end, but it doesn't look like it would allow me to get very low because of the brackets it comes with.
Now for the rear, is it worth buying a ART Air4Link kit and using my own bags, or just buy a 4-link kit from SD.com and be done with it.
Thanks for any help!
cantlooswit22s's avatar
cantlooswit22s
i had stock lowers and tubular uppers (only diff was balljoint angle) with beltech spindles on mine wen i had 22s...thats all i needed,buti had 285-30-22 on mine...the rear i havent looked at the ART kit,so duno.but it most likly wont lay out with it.mite be better off gettin S.D kit or fabbin up your own.and you gota either raise your gas tank,put it the bed or get a fuel cell.it hangs down quite abit.and a new tranny x-member.
belowclvl's avatar
belowclvl
WITH IT HAVING RACK AND PINION STEERING AND THE A-ARMS SITTN LOW WHAT IS THE BEST WAY TO LET GO LOWER. DO CUSTOMIZE A CROSS MEMBER FOR THAT OR GET A NEW OR WHAT?
