16 steelies with a 5on5 bolt pattern. Please help!!
bodydropped50
Edited: 7/19/2008 4:13:00 PM by bodydropped50
Im doing a 1994 Chevy fullsize and am making it into a "shop truck" and would like to run steelie wheels on it. I am bagging it so my stock 15's wont work with the drop spindles so I need to go bigger. Is there a steelie wheel off another truck or anything with the same pattern the I could find cheaper than buying a new set of steel wheels? Better yet can I lay out on my 15's with stock spindles?
BS
beyond static
I ran 15" steelies with drop spindles on my '90. Had to trim the edges of the lca's, but they fit. It was a close fit however. Maybe 1/8" between the tierod end and the inside of the wheel. You'd have to run around a 23" tall tire to lay out without drop spindles.
bodydropped50
Wow that would be a little tire! That would be a 195/50/15. Better go with a larger rim then.. Anyone else have any ideas?
bodydropped50
Come on guys, someones got to have so more info..
ostncoln's avatar
ostncoln
you can get thes in a 5on5 in 16" and 17" from wheel vintiques
ostncoln's avatar
ostncoln
or go to stocktonwheel.com they have some
frank_ice's avatar
frank_ice
Edited: 7/23/2008 1:23:41 AM by TheBlingKing
I have a set of 16" smooth steel wheels on a caprice. They are a aftermarket hotrod wheels powder coated black. They are 16x5 and 16x8. I got them off ebay used but they look new.
bobogolfcart's avatar
bobogolfcart
i ran 15 on mine i belive they were off of a astro van "not 100% sure though im just going off what the guy said" i got all 4 wheels caps and beauty rings for $60 from pamona swap meat they are radial tires they are similar size as a 215/75R15 no rubbing bagged and doored
http://www.streetsourcemag.com/uploads/OwnerProfiles/bobogolfcart/511200813812AM85921_tn.jpg
