draggin body
draggin body
dragitall
i dont want to drag body, its too hard to fix, i just want to drag something i weld on and doesent tear up my truck. then when its worn out i take it off and weld another on, and my body is fresh'n not fucked up.
slammedstroller
just shim up your cab and bed with a couple of washers and let the frame drag
dragitall
i just lay body tho, frames bout an inch higher than bottom of the cab,
CS
cheeks Sunset SD
sounds like you needs some gay blocks you can find them at gayblocks.com just messin with you man but really drag blocks are your only option other than plating the rockers.
dragitall
well iv got some thick steel 1*1's ima bout to weld on the frame, that should do the trick
slammedstroller
I don't know about that! I'm gonna be draggin body and frame at the same time f'n up two paint jobs lol
no1lowr's avatar
no1lowr
body is the only thing that really drags...
