re7 bags
low_stranger@yahoo.com's avatar
re7 bags
nightmare_ranger's avatar
nightmare_ranger
will re7 bags fit on the front of a 88 yota? if so will i have to modify anything?
h2omelon(nick)'s avatar
h2omelon(nick)
RE6s would be a better fit
skip1100's avatar
skip1100
I have re7s on the front of my 92. i had to notch into the frame to get em to fit. the bigger bag rides like a dream! it takes alot more cutting but it is worth it
granth's avatar
granth
you have to cut out for 6's too, the way mine is done 7's would bolt right in and have plenty of room from just lookin at it.
granth's avatar
granth
the only thing that might hit is the upper ball joint and thats only because the bag is pretty far out from the frame. 7's would be a pretty easy fit really...
TwistedMinis's avatar
TwistedMinis
I have 7s on mine. I notched the frame an inch to recess the bag. Running slams helps because they balloon less and you can tuck the bag farther in the frame.
granth's avatar
granth
if you look at www.myspace.com/candoinstalls they have a full install and they use 7's. he used some 5 inch pipe and cut it in 1/3's i guess and used that for his "frame recess". it looks stupid clean and actually is like that for a reason.
skip1100's avatar
skip1100
they do fit easy. you just gotta watch out for the tie rod and like said above recesses it in enough so your ball joint doesnt hit them
nightmare_ranger
hey seth do you have a pic of where you notched the frame.
s10tukin22s's avatar
s10tukin22s
what slam bag equiealent to the firstone 2500???
and are the better for the front of a tacoma???
