350 TOYOTA RADIATOR?
thebrantleys3@gmail.com's avatar
LndRanger86's avatar
LndRanger86
I JUST AQUIRED AN 87 YOTA BODYDROPED TRADITONAL 2 3/4". IS THERE A RADIATOR RIGHT OFF THAT WILL BOLT IN THIS THING BTWEEN THE RAILS AND COOL IT ENOUGH, BEING AS THIS TRUCK HAS A 350 BOLTED IN IT.NO TRANNY LINES ARE RUN AND OR A RADIATOR YET. CAN ANYBODY HELP.THANKS
Toddgoesfast
NO, you will need to have a thicker core installed into the stock upper and lower tanks or have one made. getting a bigger core, say 3 or 4 row HE (high efficiency) would be the cheapest and easiest way to go.
SPICY
i used a 94 dakota radiator in my taco it has 3 cores and a tranny cooler and fit good between the frame
LndRanger86
THANKS GUYS. I DON'T HAVE THE FACTORY RADIATOR. I'M GONNA LOOK FOR SOMETHING CLOSE
stumbledin
your radiator only has one core. it can have 3 rows, in which case it would be called a 3 row radiator.
the aluminum and plastic radiator for a late model vette might fit with a little trimming.
Thebutchershop's avatar
Thebutchershop
ummmmmmm im havin a hard time remembering the name of the company that makes it, its the same compay that makes the motor mount adapters to put the 350 in that truck , thaey have a radiator that bolts up , ive used it a while back for a redneck truck i put a 350 in , they brought me all the parts i jus cant think of the dam name , ill seee if i can find it
granth
downey offroad....advanced adapters....north west 4x4 i think is another one....
LndRanger86
THANKS. I'M SURE THAT ITS ADVANCED ADAPTORS. A GUY HERE WHERE I WORK HAS DEALT WITH THEM BEFORE.
Thebutchershop
ADVANCE ADAPTERS IS THE ONE THEY USED ! GOOD SERVICE
