sheet metal door panels???
ticktock200
ok ive made 2 sets of door panels incase i screw up. and i always screw up, but the question i have is. how the hell do you install something like that. i dont wanna weld it incase i have to replace windows or something. so what are the options, never did this. also anyone with pics of their mazda's metal panels? door that is, inside for the smart azz's
dragggn's avatar
dragggn
rivits
sheet metal screws
double sided tape (witht he screws in the arm rest holding it on too)
slots for the sheet to slide in...
not sure what you want the finished look to be...
make the "door panel" wrap around tot he jambs so the mounting screws are hidden when door is closed. ???
phillip's avatar
phillip
ive seen people use silicon or urethane on custom panels
I
insaneautoconcepts
On the Red and silver 2 door blazer we built we used upholstery grade 2" velcro. Worked great almost to good too.
granth
duct tape
okcderek's avatar
okcderek
I say rivet over screws.
ticktock200
i'm going for the slick clean look, but i guess the rivets idea wouldnt be bad, but are they certain amount that i should use, could i get away it maybe 4 one in each cornor and then let the rest of the stuff hold it, the door handle, and opener or should they be around 10? also where did u get the grade 2 velcro?
I
insaneautoconcepts
We got it from our upholstery supplier. If you check around with some auto upholstery places they should be able to get some for you. It has a good tacky side that will stick to just about anything. If your looking for a good clean set up try this first and if you dont like it just change to rivets. We had no problem.
jdm customs's avatar
jdm customs
yea, i would imagine that if you used velcro the whole way around that thing would stick like a mofo.
