cool ride by art
cool ride by art
Q
quinn625
1996 mustang, the back bag have ahole in it can i replace it with a another band or go with the same one and what bands will fit or the same size as firestones single 3/8 holes with studs coming from the top of the bag.
impulse's avatar
impulse
engrish??
TwistedPhil's avatar
TwistedPhil
ART uses Firestone bags. If you replace just one, stick with the Firestones, but if you're willing to replace both then you can go with any other brand that fits- I'm not sure which bag they use on that kit, but I think it's a 255c, or a 6" bag.
If that's the case, then a Slam Specialties RE-6 or an AirLift Dominator 6" bag would work well.
Good luck!
oldskool66
really you should also ask how a bag got a hole in it. there not known to just get holes.
Q
quinn625
which one is better salm or stones
TwistedPhil
That depends on what you're looking for. The Slams tend to offer a more controlled ride due to their stiffer sidewalls. They also balloon out less (which could help with whatever caused your last bag to fail), and lift higher.
However, the Firestone bag drops about 1/4" lower than the Slam, so you may lose drop if you switch...
Firestones also tend to be a few bucks cheaper, depending on where you shop.
My choice is Slam bags all the way, but again I'd recommend replacing them in pairs!
Low_Smooth_Cool's avatar
Low_Smooth_Cool
Edited: 7/25/2008 7:52:08 AM by Low_Smooth_Cool
I am concerned with how you punctured the bag. give use a call 812 482 2932... Our kits are designed to use a firestone air spring with height, lift, and drop taken into consideration... Slams are nice bags but with some of the applications I would not recommend them. As far as which bag is better deppends on who you ask, I've ridden both and since I now lean toward stones
Q
quinn625
my valves was stuck open when i try to lift or dump and so thouht it was the bag thanks everybody out there.
s10
last post by baha +1y
