i was at the bar last night and my blinkers stopped working...anyone know what could have happened? the fuse is good the blinker switch is new...what the hell.....draggin ass til the truck blows up
yourbabysdaddy
if all your bulbs are good check the actual flasher (relay, i guess its called) usually in the fuse box circle looking plug in thing.
DollaBill
Check the blinker fluid . . . . .
93mazdawg
check your flasher! little green sqaure looking thing that plugs in under the dash
StreetNshow.com
..beat me to it
karathos
Also look above your inner wheel well. There should be a white plastic thing bolted to the truck with a bunch of wired comming outa it. This is a grounding block. Make sure its good.
