sway bar
sway bar
1lowrngr
wen you replace the x-members with raised ones and put on the raidius arm relocators dose it effect the sway bar? and this is one an 87 ranger
dan48p's avatar
dan48p
it shouldn't but if your talking about bagging the front you will probably want to ditch the sway bar alltogether
bodydropped85's avatar
bodydropped85
if your talking about the radius arm sway bar it will have to be removed or u can make some brackets to hold it on there if u wantedto keep it but if you have 4 valves in the front you shouldnt need it anyways.
suicidemazda's avatar
suicidemazda
oh so u dont even need the sway bar?? cuz i thought u had to have it
dan48p's avatar
dan48p
shit i didn't even know they made the trucks with a sway bar that mounted to the radius arms. must be real early chassis like what we are talking about. all i've seen are mounted to the front of the ibeam.
with 4 valves in front, you shoudn't need one, but if you only have 2 for the front (both bags on the same air "circuit") the air compressed out of one spring will transfer to the other and dip the truck real good.
menace's avatar
menace
just get rid of the sway bar, i took mine off when i lowered mine, and it rides like a caddy...
aon-teach's avatar
aon-teach
Throw it away. If you need more valves let me know I have some extra smcs. Listen to your old teacher for once!
