Mazda Trucks \  puttin juice on the front of a b2200
Mazda Trucks Make Specific
views 234
replies 3
mmh2006   +1y
ive got a buddy that has a '89 b2200 and its got juice in the rear but doesnt in the front and hes wantin 2 get it down in the front. hes wantin me 2 help him install it since ive worked on a few trucks but i dont know anything bout juice an installin them. im only use 2 doing air ride. my question is what does it take 2 install on the front end. ive never worked on a mazda either so i was also wantin 2 know if theres anything that half 2 be removed or anything. just needing all the info i can get before i start on it. i like knowin stuff before i start workin on stuff. any info would be appreciated.
AON-OFFDAHOOK   +1y
Cut off the upper and lower shock mounts. On the lower mount, weld in a uniball*, and weld on a gusseted upper mount off the frame with a hole drilled just large enough for the cylinder to come through. A coil goes around the cylinder (or pipe to act as a spacer if using accumulators). You will likely have to notch out the control arm for clearence for the new mount.
*or you can use a heim joint
bodydrop99ranger   +1y
any pics
smithchassis   +1y
powerball will work best cce powerballs are the easiest to use. you might want to check battery prices... they are higher than hell right now... and we need 14 of them lol
