Mazda Trucks \  five lug mazda
five lug mazda
Mazda Trucks Make Specific
views 803
replies 12
following 8
duallytkn22s   +1y
what would be the best way to turn my b2200 into 5on5 chevy bolt pattern trying to fit some billet wheels that i already have and dont have money to buy another set.
duallytkn22s   +1y
i was thinking of building some control arms with chevy balljoint and just put a chevy drop spindle
toddluck   +1y
toyota conversion
duallytkn22s   +1y
Originally posted by toddluck
toyota conversion
toyota is not 5on 5
TwistedPhil   +1y
I don't think the Chevy spindles will work out for you- I would imagine that they're significantly taller than the Toyota spindles, which would put your control arm angles all out of whack.
Can the Toyota hub be redrilled to a larger pattern? If so, you could have your hubs and rotors drilled to the correct size...
Good luck!
josh   +1y
i did a 01+ silverado spindle and rear axel swap on my mazda. just so i could run big brakes without the hassel of getting them from phattys and keep it 6 lug. i made new control arms.
josh
duallytkn22s   +1y
any other ideas
pootytang   +1y
swap to toyota and try to trade your wheels for a set of 5 on 4.5
duallytkn22s   +1y
is that the same as the s10
smithchassis   +1y
5 on 5 wont work because most of them are rwd offset, an s10 is 5x4.75 and 5 x4.5 is toyota. go with toyota... easiest to find wheels for becuase if your going low you will need fwd offset
