air bags
kennethsonnier@yahoo.com's avatar
air bags
customforlife's avatar
customforlife
ok i have an 98 single cab chevy trucki got the air bag cups for the front and they dont have any bolts welded on them or anything.how would i go about mounting them in place?
simple-pleasurez's avatar
simple-pleasurez
you need to have a bolt welded in the top cup.
customforlife
ok so what about the bottom one
alwaysLow101
top has one long bolt to go through the hole where the shock bolts, and the bottom have to on them, they go through the holes where the shock is bolted in between the coil spring on the lower control arm
customforlife
ok that makes sense thanks
alwaysLow101
No problem
Balzout Sparkin's avatar
Balzout Sparkin
The lowers don't necessarily have to have bolts, it will just sit in place. OR, you could just plate the lower arm and bolt the bag straight to the plate.
bodydropped's avatar
bodydropped
most lowers float aka just sit there so if you jack your truck up it wont hurt the bag as much as it being bolted with no limit straps, if its bolted it can stretch the bag so much it could tear it internally or externally
