Center sides of hood and fenders on 81-87 pup
galbraith54@msn.com's avatar
sundown's avatar
sundown
ok basic question but still wanted to toss this out there for those of you with this first gen pup.My hood and both front fenders are off diffrent trucks...basically I have four diffrent trucks being represented on one frame *hangs head in shame*. All the tin is straight, hence it being on my truck now but the issue I have is that while everything lines up and bolts up fine, the center-sides of the hood dont sit at the same height as the tops of both front fenders. The front of the hood and the back of the hood sit right however.Looking at a few stock trucks there doesnt seem to be any kind of stock adjustment bumpers, other than some rubber pieces. I have those and they dont do anything. What are my options here? Would aftermarket adjustable hood stops look rigged in your opinion? I'm asking for more level heads to prevail here and toss out some ideas. If you all need pics to better understand what Im talking about I can post some up.
bdydrppup's avatar
bdydrppup
your talkin about the area of the hood above the tires bulges and the front and rear of the hood dont? if so mine does but its because the tires push it up when layed out lol but for real is that what you mean?
sundown's avatar
sundown
exactly, but see mine are like that all the time and the fenders are sitting good and flat against the inner fender so Im not sure what I could possibly do besides try and bend the hood in the center so it sticks up and is level or get some hood bumpers to see if that will work.
I might try sticking a 2x2 under the hood and gently push the hood down over it to create a slight bend?
bdydrppup's avatar
bdydrppup
hmmm good question to be able to do it without warping anythin
Related Discussions in Isuzu
