cab leak
lo_and_slow@yahoo.com's avatar
cab leak
domer's avatar
domer
i have a 97 crew cab, and last night it started raining really heavy, well this morning i went out and i have a leak in the cab, the front center of my headliner is soaked, and my cup holders were out, and the right one is full of water... do you think its the windshield leaking? or possibly one of my clearance lights?
thanks
chuckietruckin
clearance light I had the same problem
domer's avatar
domer
cool, thanks. ill take a look at it tonight when i get home.. did you just take it off and put some silicone around the whole?
someotherguy's avatar
someotherguy
Almost always the clearance lights, you may find you need to replace the lenses because they're warped or cracked. Overtightening the screws kills them.
The factory screws have a little gasket of sorts on them, just a ring of black material that helps seal the screw against the lens. Dunno how good a job it does. I suppose some silicone would be better, a small dab of clear in the hole then put the screw back in. If they keep leaking you might pull the lenses and gaskets and run a bead around the large hole for the socket on the roof then plant the gasket back down on top of it.
Richard
0
01power
hey domer.... i like the look of your chevy, i was wondering were you got your lowering kit from. I've been looking around and i can only seem to find them on airbagit.com but they dont you a very good detail about them. Thanks for your help.
domer's avatar
domer
Mine came on my truck when i bought it, but i think western chassis has the spindles and coils for the front, and a flip kit for the rear. its a 5/7 drop and i run helper bags on the rear.
