Page 1 of 4
Chevy/GMC Trucks \  Z-10
Z-10
views 544
replies 32
following 13
KEEF   +1y
Shanon's c10 from LA came in for z-ing front clip, redo front cups to lay, rear upper shock mounts and front/rear wheel tubs
rear shock mounts
For some reason the dumbshit welded the bag plates in
I fixed it and made short lower cups since he had 4" tall ones in it
After modifying cups but before Z
Gotta go bye bye
KEEF   +1y
Got the Z completed and ready for reassembly, modified and raised trans xmember and welded studs into frame to bolt it in, took gas tank hump out of frame, and also relocated e-brake bracket and cables .Did a few nice looking gussets for strength hump gone
still2low4urho   +1y
looks good....anymore pics?
KEEF   +1y
Got all the steering back together this afternoon and had to notch the drivers side upper arm to clear steering shaftGot the front cap back on and adjusted and trimmed the fenders for tubs and also got the tubs cut and ready to weld Front tubs complete, hood, radiator, and all back on so front is complete. Started on rear tubs and got them shaped and tacked in. In the morning gonna fully weld them and make filler panels and weld em in. Shanon is picking it up around lunch tomorrowNice cutting by Jester Metal Works
FullSizeRST   +1y
sweet ... man just moving the bag cups in the front you layed out another 3in. then you zed it to lay it the F out .....bithchen man!
KEEF   +1y
Yea the guy said it sat as low before the dood in LA bagged it as after
FullSizeRST   +1y
sorry keff you got to speak lamens terms here im not this bright?
KEEF   +1y
The truck owner said the front of his truck was as low before bags as it was after
FullSizeRST   +1y
gotcha sorry man im a little slow ..... sick work btw man! how long was his truck at your shop?
